Pioneer 5090 Questions!
Bazzy
18
Hi All,
I really feel very bad and guilty at the moment because I just bought a Pioneer 5090 plasma when I should not have (nor could I really afford to do so!) but with prices reported to be going up again, the 5 year warranty deal soon ending and a false press rumour that Pioneer were no longer making any integrated sets after April, I felt if all that was to happen then there will be no way then I will ever have the option to afford one. I really hope I did the right thing - maybe I should have waited for the new Panny V10's?
Anyway, the main question I would like to ask is if the 5090H which is the European version (but which I have noticed many in the UK too have) also has a fully functioning Freeview Tuner and EPG (Electronic Programming Guide as well? I have not yet received mine and just in case I end up with one of those, I want to make sure that it has the same functions and features (more would be better, less is definitely not acceptable as it has cost me an arm and leg!) as the UK ones? If I get a 5090H version, should I be worried or be concerned about anything at all? The Pioneer web-site (from what I can tell) does not mention anything about Freeview on the 5090/5090H unless I missed it. I would be very grateful to hear from any 5090H owners and/or the WHF team!
Thank You!
Bazzy!
According to the Pioneer UK website, both are available on the 5090 model:
Main Features
* Diagonal Screen Size 50-inch / 127 cm
* Screen Technology Plasma
* Full HD (HD Ready 1080p) Yes
* HD Digital Film Direct 24 Yes
* Resolution (horizontal x vertical) 1,920 x 1,080
* TV Tuner Integrated Digital DVB-T and Analogue
* CI Slot Yes
* Speakers Optional high grade side and under-mounted speakers available
* Input Terminals 3 x HDMI, 1 x Component, 1 x RCA AV, 3 x Euro-SCART, 1 x CI slot, 1 x PC input, 1 x USB port
* Output Terminals 1 x Optical, 1 x RCA Audio, 1 x Headphone, 1 x Subwoofer Out
* Optimum Mode Yes
* Home Gallery (+) Yes
* Via PC Card Type II adaptor.
* Multiscreen Options (PiP/PaP) Yes
* Electronic Program Guide Yes
* Dimensions (W x H x D) 1.233 x 723 x 93 mm
* Weight 33,5 kg
* Power Consumption (+) 420 W / 0,3 W
I am not sure but your dealer should certainly be able to tell you!
Other than that, it's a fantastic set. I'm sure you'll enjoy it.
Full specs for the European PDP-LX5090H can be found here.
Both of the options in question are available....
Hi All,
Thanks for the replies! I am glad that the freeview will work as I just did not want yet another external box and more wires cluttering up the space - it's amazing how spaghetti junction soon develops with just a few cables! Never did I really believe I would be able to get a Kuro! Still a little worried about whether it might be a little too big as my fixed viewing distance is just 8.4 feet but some kind folks here seem to believe it should be OK! It's basically the SD TV programmes I am only concerned about! Now, if I end up with square eyes or thick glasses, you will know why!
ÿ
Suave!ÿ
Hi
I got my 5090H this week better than the standard 5090 as it has an ethernet connection which is a plus for me, very happy with the panel glad i took the plunge i would have kicked myself if i did not get one of these before they go.
Regards.
Hi
Thanks for the input - I am too happy for having the 'H" version - I really wanted the DLNA networking option. Comparing the specs between the 5090 & 5090H, the latter really has a considerable number of features more than the former, it is almost the same as a KRP model! I have read that it also has a nicer user interface and some sort of preview function when switching channels or sources? It is missing the Polish language setting over the 5090 but to me, that's a blessing!ÿ
Bazzy!ÿ
Ah, after much deliberation I thought I'd chosen my new tv (a 5090); however things just more complicated when I realised there was an H version available, which would compliment my wireless network. So, back to those that know - is the H worth the extra, is it available and what should I expect to pay? I'd negotiated the 5090 down to £1850 with a local Pioneer dealer and was wondering how that compares with other real time deals?
Bunsen Merrydew:Ah, after much deliberation I thought I'd chosen my new tv (a 5090); however things just more complicated when I realised there was an H version available, which would compliment my wireless network. So, back to those that know - is the H worth the extra, is it available and what should I expect to pay? I'd negotiated the 5090 down to £1850 with a local Pioneer dealer and was wondering how that compares with other real time deals?I got mine for £1749 from Sevenoaks with 5 year guarantee without negotiating
Thanks, rgbdirect have the 5090 advertised in this month's Whathifi at £1649 - too good to be true? "I'm sorry Mr Merrydew that offer has now ended and there's been a price increase. The new price is £1949!"
