Phone killing amp
danny-79
52
29
570
Hi all !
So quick ish question. My phono keeps making my amp cut out or switch into a standby mode. You can tell it’s unimpressed by it slowly turning its own volume down to nothing then switching its self off, thats after its killed the initial signal.
(I did also put the stylus down a bit sloppily and this also caused the shutdown)
Along with this the amp is also getting very hot when playing lps. (Possibly being driven harder than with cd)
It’s a Marantz amp, pretty basic from around 2014 with a project carbon, ortofon blue cartridge.
I’m using the amps inter grated phono stage.
Cd, tape, all work great at any volume without a hot amp.
Thanks in advance
Deleted member 108165
Sounds like you have a sick amp. Do you have another phono-stage you could test connect to?
Normal for Marantz amps to run a little warmer warmer when using the phono-stage as it needs more juice to amplify the signal, but it shouldn't run hot to the point of shutting itself down. Is it shutting down or going into protection mode?
danny-79
52
29
570
Thanks for reply’s. I’d say it’s going into protection mode. It’s stays powered up, the volume control turns itself all the way down after the signal shuts down.
I’m using the amps own built in phono stage, I don’t have an external one but I’m thinking that could be useful upgrade. Amp works fine otherwise with other sources.
Tinman1952
That sounds like a good idea 🙂 You won’t have to spend a lot to improve on the built in phono stage….👍
Doesn't sound like protection mode as that mutes immediately and requires a wall switch-off to reset. The phono-stage in the Marantz is very good so you have three options: replace the amp, get it fixed, or purchase an external phono-stage of reasonable quality and keep the amp.
danny-79
52
29
570
Ok. So next question is can you recommend me a phono stage,
The overloading/cutting off of the amp, you do have to manually switch it off to get it to work again. Possibly I’m driving it too hard, it’s only at decent volume so hopefully it’s user error.
So add a phono stage. Can you recommend something half decent please
danny-79
52
29
570
Unfortunate name but u keep coming across the Nobsound T3. In searches. It’s appealing as it has a gain/volume control (looks user friendly anyways)
Anybody know anything about them ?
danny-79
52
29
570
Or even the Little Bear T7. Seems pretty cheap for something with tubes at under £60, (apart from replacing tubes every so often is the only negative I can see but I’m used to that with guitar amps)
Out of the two I’ve mentioned what would serve best ?
Thanks again
Tinman1952
Yes unfortunate name…😣 but it’s a brand of Douk Audio which is quite well respected by those who try these chi-Fi products. I have a Nobsound class A power amp which is built like a tank and sounds wonderful. They often sell through Amazon for your peace of mind or the ‘bay’ 👍
Don’t let the price fool you…they are very well made with high quality components.
danny-79
52
29
570
Thanks. That’s what I thought, mixed reviews but some of the negative ones are either old of not very detailed (it’s crap doesn’t really help. Why is it crap?) but anyways I think it’s going to be one or the other just don’t know, T3 is possibly the better but the tubes look pretty good in the T7.
What are my advantages/disadvantages of either?
Tinman1952
Well that’s a personal choice of what you like your music to sound like. People who love tubes would say more ‘air’ in the music, larger sound stage and better imaging…… many love the ‘little dot‘ headphone amps for example. 👍
danny-79
52
29
570
Yeah I’m a fan of tubes in Another life so why not. I’ll give it a go I recon
Reactions: Tinman1952
danny-79
52
29
570
It arrived today. Need to make up some cables but linked it together with what I’ve got, definitely a noticeable difference between the built in phono stage, hard to describe. It sounds wider for lack of better words. Won’t commit any more than that till I’ve spent more time with it but for now , at under £60 great upgrade
danny-79
52
29
570
I thought I’d dig this up for an update
I’m still very impressed with the Little Bear, I’ve tried a couple of different sets of tubes in it (lower gain rated as that’s what I use in my bass amps preamp) to little or no different (to my ears anyway.
The electrical fault of the amp cutting out turned out to something far more sinister with the house electric supply but that’s another very boring story so I’ll spare you that one
