Panasonic 42G 10 - What sound shall i have?
Hi all, searched the forum but to no avail. By the way, this is my first post.
I'm buying a Panasonic 42G 10 this week, I had Sky with HD pack installed last week. What should i do in terms of Sound?
Should i buy a;
1. Home Cinema Package
2. Or, should i buy a AV Amp and a decent set of speakers? such as NAD C326BEE
Any advice?
Vandyer
A separate AV amp and speakers will give you better performance than an all-in-one home cinema system, but obviously the latter is more convenient and easier to install. And BTW, the NAD C326BEE is a stereo amp, not a multichannel one, so not what you need in this case.
For some ideas on a good budget home cinema separates system, check out our Best Buy budget system, or alternatively our 5-star all-in-ones if convenience is key.
