Our Lounge
wilro15
74
Nice: you've got some great kit there. How do you use the Anti-Mode? It's a bit of a Swiss army knife.
If it were me, I'd think of throwing something absorbent (e.g. a nice blanket) on the leather sofas: leather does reflect sound. We used to have leather and recently changed to fabric. It makes a big difference.
*drinks*
The Anti-Mode sits in between the Bluesound Node and the DAC, so it is all digital connected via Toslink. I have actually used it as a DAC too in the past, its not bad, but the Abrahamsen is a little better.
The canvases on the wall are actually acoustic panels. I had the canvases printed professionally using a process called dye sublimation (I think!) and then packed the inside with acoustic absorbing material.
Sofas could be an issue... I might have to think about covering them for serious listening sessions! Thanks for the tip.
Yay, the post worked. The pictures are a bit stretched though, strange because it looks ok when editing.
My latest addition are the Tannoy Precisions.
