Hi all, I replaced my old Onkyo receiver ( can not recall model number) in June 2015 .. with the 646 -. I have had no issues with it until now . All of a sudden - I have no video or sound from it.
The Tv recognises a source is connected ( HDMI2- ARC)
But I can not get OSD . Well - I can .. if I reset the receiver.
Then when I have the choice would I like to check the source connections are made correctly - I choose “yes” ( I only have the Arc cable connected - so choose Tv on the choice I would like to check ..- it comes up with “is the picture and sound right which you wish to connect” ... and I hav no picture or sound... so I ten choose “no”.. so then it abides to make sure cables are connected ( which they are.. and I have tried a new cable too) and asks to make sure power source is on - which it is.
Any advice would be appreciated... I have heard Onkyo have admitted faults with some models ( HDMI - board) but not sure if it covers my model
