(not so) smiley
jimdonnelly
46
When I make a post or reply to post I do not have access to the smiley icons. They appear on screen for a few seconds then disappear. Everything else works fine. I have tried using a couple of different browsers but the problem remains.
Does anyone have any ideas what is happening? Is it a problem with my computer?
Any help or views appreciated.
Thanks very much Andrew.
Hi Jim - do you happen to use Safari or Chrome, out of interest? Because I know that the editor has issues with those two browsers - if this is the case, you may be better off with the text-only editor, which at least will allow you to format posts manually (though one of s will need to change it for you).
One of the things we'll be fixing shortly...
JohnDuncan:Hi Jim - do you happen to use Safari or Chrome, out of interest? Because I know that the editor has issues with those two browsers - if this is the case, you may be better off with the text-only editor, which at least will allow you to format posts manually (though one of s will need to change it for you). One of the things we'll be fixing shortly...
John
Whatever Andrew did has worked. I use Explorer, although tried several others like firefox and safari. They had no effect.
I am now like a kid in a smiley shop
Hi, everyone, could someone help, please? I've recrently upgraded from Vista to Windows 7, and have problems inputting test when replying to posts, and also cannot view smileys - all I get is a box, with a red cross and a text description of the smiley. Where should I correct these, please? I had to disable rich text to enter this query.
