no sound HELP
ok on arrival to my holiday destination i discovered that the left side of my headphones is not emiting any sound at all afther some checks i found out that the cable is broken internaly probably ript or cut but i cannot see where i just know that depending on how i hold the wire it might give sound but i must hold it absolutely still now i've got the headphones second hand off my chef and he got them online so it seems i cannot take them back to the shop on my return to london so what can i do ? can i replace the faulty cable ?where? i realy like the sound of my headphones and would like to keep'em also i dont have a spare £100 to replace them with new ones so what are my options please help me im desperate!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
The perils of buying used stuff from a person rather than a shop...
Take it to the shop and see if they'll fit a new wire/plug...
[quote user="BigGuads"]The perils of buying used stuff from a person rather than a shop...
Take it to the shop and see if they'll fit a new wire/plug...[/quote] thanks mate do you have any idea wich shop ? i live in london and im afraid any shop will send me away has i have npt purchased the item it theyr shop
[quote user="gpi"]Are you Vicky Pollard?[/quote]
are you able to offer advice or merely banal comments...
to the OP, what brand are the headphones? have you tried emailing them? if not, then send them an email ommiting the fact you didnt buy them new and that you need to replace/repair the leads. i would be very surprised if they didnt tell you where you could find someone to carry out the procedure.
[quote user="ifitsoundsgoodlistentoit"][quote user="gpi"]Are you Vicky Pollard?[/quote]
to the OP, what brand are the headphones? have you tried emailing them? if not, then send them an email ommiting the fact you didnt buy them new and that you need to replace/repair the leads. i would be very surprised if they didnt tell you where you could find someone to carry out the procedure.[/quote]
Someone else with a sense of humour bypass.
[quote user="gpi"][quote user="ifitsoundsgoodlistentoit"][quote user="gpi"]Are you Vicky Pollard?[/quote]
Someone else with a sense of humour bypass.[/quote]
no, someone else that would rather help fellow forum users than make pointless and unhelpful remarks
[quote user="ifitsoundsgoodlistentoit"][quote user="gpi"][quote user="ifitsoundsgoodlistentoit"][quote user="gpi"]Are you Vicky Pollard?[/quote]
no, someone else that would rather help fellow forum users than make pointless and unhelpful remarks[/quote]
http://whathifi.com/forums/p/11020/71274.aspx#71274
My dear boy, try lightening up a little and join in a bit of light-hearted banter with us all. There was no punctuation in the OP's opening post so I thought he sounded like that Vicky Pollard character. I also thought about posting 'and breathe out...' Anyone else have a problem with that?
BE GOOD BOYS OK ? DONT FIGHT . SORRY ABOUT MY PUNTUATION BUT I AM NOT ENGLISH AND TO TELL YOU THE TRUTH I REALLY DONT GIVE A S(/&T ABOUT IT ...........YEAH BUT NO BUT YEAH BUT NO BUT ....... BACK TO SERIOUS STUFF NOW I DONT FANCY MAILING SOMETHING OFF TO SOME ONE I DONT KNOW TO GET IT FIXED I RATHER GO TO A SHOP WHERE THEY FIX THIS KIND OF STUFF ANY BODY KNOWS ANY SHOP LIKE THIS IN LONDON ?
[quote user="professorhat"]Whereabouts in London?[/quote] in white city but can move to wherever is needed
audio technica ATH-ES7 retail price just under £100 on line all that is wrong is that the cable is ripped inside just at the bottom about 5 inches from the jack i dont want a different make model i prefer this ones top the grados because this ones are sealed and hold the sound better in the train and noisy enviroment please advise Andrew
In which case clicky here. Or any competent repairer should be able to cut off the cable above the break and solder on a new plug for you.
Try putting 'audio repair' and your postcode into yell.com.
Andrew as always you are the man ,thanks mate i how you a pint actualy its probably 100 pints
called audio thechnica today and i was glad to find out that for £25 it will all be sorted including vat labor cable and maling expenses very kind and helpful service aswell
