Hi there, I am new on this forum, my name is Tom and I just started rebuilding my home cinema system, slowly upgrading speakers, cables etc. I am on budget and I guess many of members spend loads of money on their audio systems, I simply cannot afford it now, but maybe one day...
Heart of my home cinema is Philips HTS3357, I have it for about 2 years now, I know it's not best one around but it works well and even if I would be able to afford to buy better now probably I couldn't really appreciate it's sound, we live in block with 3 kids, so it's quite noisy here most of the day and I can't really listen to music/watching movies loudly at night, anyway, I am usually knackered after everybody goes sleep so I finish playing some game or watching some short things, which don't require best sound possible... I bought set of Acoustic Solutions speakers (I am on budget, remember) and replaced all original Philips ones with those (except subwoofer, but I am going to look for one soon). I got some nice cable as well (nicer than before, anyway).
Philips HTS3357 is amplifier with integrated DVD player, but being honest I don't remember watching any movies on discs for a while now, all my music and films are on my computer, which is connected through HDMI straight to TV, as my amplifier doesn't have HDMI input. Sound goes through normal stereo cable, connected to AUX input. My computer is in corner opposite to TV corner, so those two cables are 10m long.
So I was browsing internet another day and I thought I will search people's opinions about HTS3357 and I found one forum, where somebody said that if you connect audio that way (analog, AUX) the surround sound effect is simulated, it's not really surround sound. I was surprised reading this, as I was happy with effects, I mean everything did work as it should be, every speaker was working as it should be, I could hear different sounds from rear ones, you know what I mean. The same person wrote that you need to use optical input to get real effect. I was thinking of upgrading my amplifier to one with HDMI or SPDIF input for a while now, as sound card in my PC (Creative X-Fi Xtreme Gamer) has optical output and I did want to use it. And then I discovered after having this system for 2 years that there's digital audio input in it!
It's TOS, tosling, coaxial or whatever you call it, so I did quick web research, and there are adapters available. So it costs only about £10. All I need is: toslink to 3.5mm converter, which I already purchased (to convert output on my soundcard to SPDIF as it's minijack socket with light in it), I need mentioned before adapter and then I need cable to connect PC to adapter and another one to connect adapter to amplifier.
I know it did take ages to explain what I mean but here comes the question(s): should I buy short SPDIF cable and long TOSlink one, or opposite? Does it really matter? Coaxial cable is much cheaper, so I would prefer it to be longer. Also, won't 10m lenght have any influence on quality?
Anyway, is that true that analog audio will only give you "fake" surround sound? If it's not true, should I really bother? Would I hear big difference in sound quality? I am ripping my CD collection to FLAC now, and I would like to hear the difference.
Congratulations if you made it to this point, I appreciate any help. Thank you
