New Panasonic TH-37PX70BA
Hi All
Just bought a new Panasonic 42" and set it up last night, but there is a constant message jumping up and down the screen which looks like it is searching for something. There is nothing in the manual and I am baffled. Is there anyone out there who can help me please?
Can you confirm whether you have just set up with an external Sky/Cable box or whether you're using a separate terrestrial aerial (analogue or freeview); it sounds like it may be the initial part of the set up where its looking for channels for the built in tuners. If so just let it finish and if your only using it with Sky or cable then you can change the setup in the television menu afterwards so that it goes straight to the input you have the source connected to.
Robert
