New Home Theatre Upgradable Setup
kingnothing83
56
I asked the forum for help with converting my current hi-fi set up of an arcam alpha 8, mercury custom f1’s and a Beresford dac into a home theatre for my living room.
The suggestions were very useful but got me thinking that it may be worthwhile to leave my hi-fi alone in another room and start from scratch with the home theatre set up, but in doing so I would like to keep it as upgradable as possible. I don’t have a mega budget by any means so I am looking at this as a solution.
Sony 2400es amp (presuming this gets some good reviews by the WHF team, if not, then id
have to spend a bit more on an onk av amp). This amp has an amazing spec for the money and what really interests me is its pre-outs, essential for upgrading the way I’d like to. Cost should be around £400.
That leaves me little budget, so for speakers I was thinking the wharfdale diamond 9 HCP. Mainly because the SW150 sub has superb reviews and means I could probably leave that alone for a lot of years.
As music would be a bigger factor than home theatre but I still want a system capable of both,
I want a system that will play music (from my pc’s bit perfect optical out, to my Beresford dac, then to my 2400es amp) to a reasonable standard. Would the music from this av amp feeding my diamond 9 speakers be a big step down from my arcam alpha 8 feeding my tannoy f1’s?
In time I would like to add a new amp via pre outs to play music, then new fronts (b&w 695’s perhaps), then backs and a sub.
Does this make sense as a good upgradable route? Or do you suggest a different set of speakers for around the same money?
All suggestions welcome!
Simon
Apologies for the forum faux pas of replying to your own post, but ive just read about the 1010i 5 in 1 package, is it worth the extra £50 or so it costs on top of the wharfdale 9's? I am slightly put off it as the sub seems to be worse than the cheaper wharfdale.
As always, all suggestions are much welcomed
Or perhaps trying ebay for 2nd hand kit would be an option?
If no one has any ideas i'll give up now 🙂
