matthewpiano
In 1999 Hi-Fi World said of the Heylettes - "Better suited to Classical than Rock or Heavy Metal. Smooth and refined sound will appeal to many."
thomaswarne said:I decided to finally upgrade from my horrible cd player and bought a DENO-PMA720 amp and DENO-DCD720 and also a PROJ-ESSENTIAL turntable. Having got everything setup, I'm not happy with the sound at all. I'm new to this and wasn't sure what to expect sound quality wise, but there's no depth to the sound. I have the bass setting to almost maximum all the time, and even then it's not enough really. I'm using some old speakers of my dad's they are Heybrook Heylette speakers. I wondered if perhaps the speakers were the problem. I have some decent Atacama speaker stands and I bought some decent enough speaker cable from a local shop. Does anybody have any idea what the problem might be? Thanks for your help in advance. Tom
Overdose said:thomaswarne said:I decided to finally upgrade from my horrible cd player and bought a DENO-PMA720 amp and DENO-DCD720 and also a PROJ-ESSENTIAL turntable. Having got everything setup, I'm not happy with the sound at all. I'm new to this and wasn't sure what to expect sound quality wise, but there's no depth to the sound. I have the bass setting to almost maximum all the time, and even then it's not enough really. I'm using some old speakers of my dad's they are Heybrook Heylette speakers. I wondered if perhaps the speakers were the problem. I have some decent Atacama speaker stands and I bought some decent enough speaker cable from a local shop. Does anybody have any idea what the problem might be? Thanks for your help in advance. Tom
You could try positioning the speakers differently, this can make a big difference.
Failing that, the problem is either the equipment or your expectations. See if you can loan another amp and a pair of speakers to see what difference either of them make to gain some sort of reference.
Blackdawn said:Probably just me, the last photo of the Denon amp. B, left channel (could be the pic or my screen) why do you have cable running as if its between positive and negative?
thomaswarne said:Just tried a cd with the levels flat and it sounded tinny. I pressed in the loudness button and it made a difference, but still didn't sound full enough to my ears. Pushed the bass right up and it came alive a bit, but I feel like it should sound great without doing those things... The bass part of the speaker is working, but didn't seem that powerful. Volume level was at about a quarter by the way...
