Need some speakers!
Just picked up a 2nd hand Sony STR-DG 820 to accompany my PS3 and now need some speakers. Managed to get a budget of £350 and so after some sensible suggestions. Quite happy to go the used route if there is a bargain to be had but need some recommendations - i understand that the Sony is quite bright.
I;ve seen the Kef 1005.2 at £299 in silver or £350 in gloss black and i've also spotted the little Jamo's. The speakers must be compact but other than that, I really have no other requirements.
Thanks in advance.
Q aquastic 1010i's are a very nice little speaker pack that punch above their weight. They are £350 at richersounds which is a bargain
I can vouch for those "little" Jamo's there brilliant, also used them with a PS3 and a Onkyo 606, sounds great to me.....
You can pick em up for approx £250- so loads left over for some BluRay's
Emmodd:Love those but just a bit big for my room unfortunately
In that case, the JAMO A102's will fit your requirements perfectly, budget and size wise.
