NEED HELP TO SET MY SUB
lussen
34
need help to set my sub frecuency impact 10 with denon 1910.do i ve to set 80hz at my sub or let my amp do it all
I set my amp to do it and its 100hz crossover, 80hz does not suit my speakers. And have the phase set to 0 I think, but thats your preference. I think most will say let the amp do it.
should i turn freucency at my sub to the limit n the volume in what position.sory my english is bad
please someone help need to know for the best setting my sub.denon1910 n velodyne impact10 .supra dual sub cable.samsung bd1400
set sub frequency to highest.
set sub volume to mid point.
run set up on amp.
amp should then set crossover points.
Hi, just to note on my sub there is a variable or bypass switch which I have this set to bypass which lets the amp sort out all the necessary settings.
My auto set up is bad.
It set my sub to -15 which is the lowest, and had to turn it back to -6 and it set my fronts and rear to large when the are bookshelfs, not capable of giving out real base, so had to turn those back.
I do it from ear now.
well i think you buy a wrong amplifier for your home entertainment..
denon is not a good amp for your home theater ......
denon is suitable for playing stereo only....
why needs helps for your subwoofer?
meanwhile your 1910 can't produce a good sound?
