Need help expanding my home cinema!!!
Hiya,
I need to expand my home cinema to bring a) my amp up to date with HDMI and b) to balance my speakers to be a complete package rather than the mish mash that they are at the moment.
What i currently have is:
a sony 40" LCD KDL40W4000
SKY HD
a pair Dynaudio Audience 42's
a Dynaudio 42C center speaker
Yamaha 5.1 DSP A5
and i have a Bose Accoustimas 10 sub and rear cubes
Basically the elements that i want to change are; the amp, the sub and the rear's. But i want them to balance well with the dynaudios. Also i need the rears to be very small speakers as they are mounted on the wall with a sofa butted right underneath them.
I am thinking of the Denon AVR-1909 for the amp (£500 ish is the budget - this will be the first purchase)
And for the sub i figured it was worth staying with Dynaudio and getting the DYNAUDIO SUB 250 ACTIVE SUB WOOFER - SUB250 or the other one i concidered is the REL R205 SERIES what do people think? Im open to suggestions.
As far as the rears go i have no idea - i currently have bose double cubes mounted and there really isnt much more room for anything larger.
I'm open to any suggestions even if they deviate from the above.
Thanks in advance for your help.
Rob.
So another senario is to buy the Denon AVR-1909, and go with the Monitor Audio RSW12 sub and get the pretty small looking Monitor audio R45 satalites - my only worry is balancing off the system - it may just be a case of going instore with my 2 dynaudio fronts and centre
Any one have the RSW12 Paired up with the R45 satalites?
