- Mar 27, 2013
- 4
- 0
- 0
TubularTechnician said:Thought as much. Copy and paste from office word this time to be sure.
Please bare with me 😛ray:
dsuciato said:I also think that a pair of floorstand is better i.e. Tannoy DC6T SE with hi-sensitivity also real wood body.
For CD player I would go for Audiolab 8200CD not only it's much better than the Marantz CD6004 also you don't need to buy the M1-DAC as you can use the 8200CD DAC already. Add the K2 Amp or 8200P, all set & make some noise 🙂
Exoticsounds said:In any case you will not really know how it sounds till you get it set-up and playing in your own room.
From a pc/mac to the DAC you can use any solidly built usb cable no special hi-fi cable is needed there, the same goes more or less also for a coax cable to connect the CD to the DAC.
The signal cable from the the dac to the amp is a bit more important and here you could spring for some nice interconnects like for instance a pair of Atlas, Chord or Van den Hul's.
The place where you are most likly to hear any "significant" difference is the speaker cables, so you could spring for a nice pair from a brand like Audioquest, Wireworld, Chord, Atlas or QED.
TubularTechnician said:I suppose I should have come to the forum with my questions BEFORE I demoed and ordered some expensive kit :?
TubularTechnician said:Exoticsounds said:In any case you will not really know how it sounds till you get it set-up and playing in your own room.
So I connect the CD to the DAC and the DAC to the amp ? Excuse my ignorance but are these digital or analogues ? 😳 I'm presuming the Sonos Connect goes into the DAC also and the ithing connects with the Sonos ?
I suppose what I'm most concerned about is that the base may be boomy in a narrow room. Is there a speaker cable in that lot that could negate that ? Wont be playing at massive volumes and I'm really looking for as much detail as I can get from the system.
Cynic-al said:Having your speakers firing across the narrow part of room away from any side walls will give you the best results anyway.
My old lounge was set up like that and it sounded fantastic.
