Nad c352 or c355?
northantsbloke34
128
Looking to by new hifi. Thinking of the above. Do i go for the award wining 352 for £299 or spend extra £50 and go for the new 355 for £349? Have heard 352 and really liked but not 355. ?
it should be easy to audition both as anyone selling the 352 will be getting the 355 any day now. i have the 355.....
I have heard both amps but sadly not together in the same system, so I cannot say which is best. They are both fantastic though. I would be interested in a comparison.
The NAD C355 is a superb amp as so is the NAD C352.
The only reason id go for the C355 over the C352 is the fact that its got 2 sets of speaker outputs allowing you to bi-wire with less hassle.
I listen to them both with the NAD C542 CDP and M/A RS6 and RS8 speakers. Superb bass, well times mid and clear treble thats just laid back enough to take the edge off the M/A speakers.
Hi mate i have a C352 have owned it from new for 2 years. its a superb amp i cant fault it my only point would be as mentioned in previous post is the extra set of speaker terminals... But the 352 does have a set of holes behind banana plugs for bi-wire...I guess you will have to listen to see the difference but if you cant i promise you you wont be dissapointed with the C352My mate has a Cambridge audio 640v2 and its better in every sonic aspect...Hope this helps
