multi channel output
hi, you have probably heard this question loads, i have a blu-ray player with multi channel analogue output, but my AV receiver cannot decode the HD audio formats over HDMI, so if i use the multi channel inputs will it be HD audio i am hearing, or would i be better of using the digital coaxial output instead and listen to normal dolby digital surround sound. Cheers
I am pretty sure that's correct, using the blu ray player as the decoder then analogue to the amp. I am hopeing to do the same soon as my amp has that problem too. Using the multi is useful too for keeping the digital inputs free for other equipment
