Monitor Audio BX 2 Amp
I know this question probably have appeared before, but i just don't think i've got enough info.
My room i 12 squaremeters and i'm planning on buying the MA BX 2 because of the good reviews, and i'm going to listen to them soon.
I am just not sure of which stereoamp that will fit. Thinking of:
NAD C316BEE
NAD C326BEE
Will the C316 be enough to drive them, or is the C326 a big improvement?
I would also like to know if there are other amp that you would recommend for these speakers but not more expensive than the C326BEE. :)
Ryan92
21
The Marantz PM6004 is probably one to check out, I personally think the Marantz - MA combination works pretty well. And available for around £250. I certainly recall seeing that combination in a few sigs on here. I'm sure responses from said people will pop up in due time.
I've also heard the 326, not the 316, though I am aware it's pretty darn good at controlling a speaker at it's price point. Pretty punchy sound for the power output if you ask me. Having not heard the 316 I couldn't comment on whether it's significatly better.
NAD C316BEE
NAD C326BEE
Hi Chosee
C326BEE or Yamaha's A-S500 is also worth a look.
All the best
Rick @ Musicraft
Okay thanks for the answers. I'd really like the marantz, the problem is just that i can't listen to this with the speakers, because i have to order them from another country. Is it worth the risk?
Cypher
156
The Marantz PM6003 or PM6004 works very well with the BX2 speakers. Can't go wrong IMO.
Ok i've found out that i can get the Marantz cheaper, but which one is most recommended? 6004 or 6003? Is there big diffenrence? :)
Thanks again :)
