mixing speakers and sub
Thinking about buying wharfedale 9.4's, 9.0's, a wharfdale centre. I was offered the kef kube 1 to go with it, two questions will speakers go well together and is the sub any good? thanks
Normal
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
@page Section1
{size:595.3pt 841.9pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Which Wharfedale diamond centre
speaker, there is the 9cc and the 9cs. I
think the 9cs is better suited to match the 9.4 front speakers, the smaller 9cc
is used on the Wharfedale 9HCP package which has the 9.0 speakers as fronts and
rears.
Regarding the sub, the MJ
Acoustics Pro 50 MK 2 retails for about £50 more than the KEF kube 1 and would
be a much better option, there seems to have been some problems with the kube
1.
Normal
false
false
false
margin:0cm;
font-size:12.0pt;
@page Section1
div.Section1
{page:Section1;}
font-size:10.0pt;
rears.
1.
lobby
161
M8 i would seriously consider looking at the deals around for the Tannoys, start with the bargain of the year and purchase the F4 customs for £119.99 at Richer sounds, you could also purchase a second pair for rears if you wanted would save an stands or wall brackets. Then f1 custom rears for £90 and centre for £90 total without sub would be £300-330. For subs i would look at BK monolith or Ts12 would cost you around £400, or the more expensive MJ Acoustic ref 100. Creative Audio are doing a good deal where you get the 5 F1 customs and MJ Acoustic sub with £135 of free speaker cable for £699 and you could add the F4's for another 120 from R S for 7.1 or sell them.This would sound much better than the 3yr old Warfedale,s and Kef Kube which is probably hard to get rid off. And if you haven't got an amp i would look at the Yamaha Ax863se for £500 or a deal on the Onkyo 875 if you can find one.
John Duncan
2,031
15
19,695
lobby:M8 i would seriously consider looking at the deals around for the Tannoys, start with the bargain of the year and purchase the F4 customs for £119.99 at Richer sounds, you could also purchase a second pair for rears if you wanted would save an stands or wall brackets. Then f1 custom rears for £90 and centre for £90 total without sub would be £300-330.
Told you. And the centre is fifty at Richers just now...
ASK THE COMMUNITY
