- Aug 10, 2019
- 2,556
- 5
- 0
My Sky+ box is connected to the YSP via optical cable.
I recently switched off the sound to take a phone call...can't remember if I used the 'mute' button or the volume control.
I then found I couldn't get the sound back.........
I've checked the various settings I can think of....the remote appears to be working OK, as far as I can tell......the different YSP functions are appearing on the visual display.
I can get sound from the DVD player through the YSP without problem.
I changed the optical cable, just in case......no fix. What's the chance of the Sky+ box being faulty?
It feels to me, (gut feel), that a 'setting' has changed somewhere, but I can't think where to look, (that I haven't already looked).
Can anyone suggest some magical combination of keys, (Sky+ remote or YSP remote), I may have inadvertently pressed, that could cause this situation?
BTW TV is Sony KDL40W2000
