L luc c New member Feb 22, 2014 1 0 0 Mar 5, 2014 #1 Hello everyone, I wish to buy the Guru Junior speakers and am looking for a recommendation for a matching amp. If possible I would like to match them with the Rotel RA-10, what do you think :?
N nima New member Jan 15, 2014 29 0 0 Mar 5, 2014 #2 I thought everybody was pairing them with Naim UnitiLite or Qute or Nait.
L luc c New member Feb 22, 2014 1 0 0 Mar 5, 2014 #3 Yes but no phono stage and a bit expensive, thank you.
Al ears Well-known member Nov 23, 2008 14,201 8,732 64,070 Mar 6, 2014 #4 Welcome to the forum. Have you actually heard these speakers. If so and you know they are going to fit in with your room then the pairing should be a good one. Even better if your budget allows it is to look at a Rega Brio R or even Arcam FMJ A19. These speakers will survive many an amp upgrade so get the best you can afford. 🙂
K Ketan Bharadia New member Jun 7, 2007 44 0 0 Mar 6, 2014 #5 While the Gurus will thrive with something more upmarket I think they'll work really well with Rega's Brio-R. It's got a decent phono stage too.
Al ears Well-known member Nov 23, 2008 14,201 8,732 64,070 Mar 6, 2014 #6 Ketan Bharadia said: While the Gurus will thrive with something more upmarket I think they'll work really well with Rega's Brio-R. It's got a decent phono stage too. Click to expand... Thanks for reinforcing what I said... the bit about the phono stage was a given, I thought... 😉
L luc c New member Feb 22, 2014 1 0 0 Mar 7, 2014 #7 Hello again, I'm also thinking about the creek evolution 50a! Anybody?
Al ears Well-known member Nov 23, 2008 14,201 8,732 64,070 Mar 7, 2014 #8 You'd have to get the optional phono stage for it but there is no reason it should not partner well with the Gurus. To make sure it is for you go and audition if you can.
P Philim New member Jan 16, 2013 13 0 0 Mar 7, 2014 #9 The gurus are lovely speakers. I have heard them work really well with nait xs or rega elicit r.
