Marantz Remote Controls
Mar 21, 2016
Hi to everybody.
I recently bought marantz CD5005 and now it is time to change my amplifier. I want to go with marantz PM6005, but I dont if I can use the same remote control with CD5005. This is important to me too because I don't want to have so many remote controls on my hands, I can really go with PM5005. But I have found a great deal for PM6005 and I want to consider that one, for sure.
Thanks!
Çağatay Nur said:
Hi to everybody.
Thanks!
your remote should work the pm6005 but you will get a remote with the pm6005 anyway and if you get the matching cd player you will get a remote with that too all the same remotes controls
