Marantz PM6006 right channel problem
ricaippo
Hi, I'm a new member and newbie to Hi-Fi audio. After many years I returned to stereo sound. I bought a Marantz PM6006 amplifier, a Pro-Ject Box DS DAC, for Jamo S805 and playback from my macbook via usb. When I connect the direct optical cable to the amplifier without going through the DAC I had a distortion problem with the right channel, it produces a constant distortion and low volume. After disconnecting it and going to analog, the problem continues and then it works correctly again. I wanted to know if any member had the same problem and which member can be a member of the solution
Welcome to the forum.
The amp is the common denominator with your problem.
Click the link and have a look at a previous thread.
It's not your model, but I strongly suspect the remedy will work for you.
No guarantees, but worth a go:
Reactions: GSV Ethics Gradient
