Machinemessiah said:What would you recommend as a speaker upgrade?
ID. said:Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
manicm said:ID. said:Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
No it won't, Marantz website states it has exactly the same amp as the new M-CR610, the same 60w. It's just a pure digital stripped down 610 i.e. no CD player, no FM.
utomo said:manicm said:ID. said:Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
@manicm
ID mean step down from current PM6004 and Arcam rDac.instead from the 610.
But we did not know because both not yet available right ?
utomo said:I hope you are wrong.
Because This year is Marantz 60 Anniversary, They must producce good products.
If not they will need another 10 year
http://www.whathifi.com/review/marantz-pm6004
only 2x 22,5 watt
No USB
No Pre out
NO FM, No DAB
No Internet radio
I will wait to see newer products
ID. said:utomo said:manicm said:ID. said:Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
@manicm
That's right. Because it is a step down in sound quality from the 6004 to the 603, I'm assuming that it will also be a step down in qualify going from the 6004 to the 610 or 510.
manicm said:ID. said:utomo said:manicm said:ID. said:Too new, so you might not get many (any) answers with 1st hand experience, but going by the M-CR603, it would be a step down in terms of sound quality.
@manicm
If you agree that the 610 is no step down from the older 603, then the new 510 is equally good as it has precisely the same amplification as the 610, the new models are on the Marantz website, if you'd care to look.
