1jonnyboy:which is the best fig 8 mains cable?
Hi Johnnyboy,
Figure of 8 connectors are limiting due to their current rating of 1A and also since they can only accept a small diameter cable and small gauge conductors (modifying the connector to accept a large diameter cable and larger conductors will invalidate any safety approvals and can be dangerous).
An IEC-to-Figure 8 Adaptor which fits onto the end of a standard IEC connector (which can usually accept larger diameter cables and larger conductors without modification) will allow a higher-performance cable to be used. This option will open up your options and you could therefore look at any power cable on the market.
Hope this helps.
Kind regards,
Darren
