Sorry to jump in on this thread but it seems to be going some way to answering my problem.
I've finally managed to get the equipment all set up in following configuration:
RS6 Bi-amped to 875
RS Center Bi-wired to 875
RS1 connected to rear outputs on 875
RSW12 Connected to Sub Output on 875
PS3 Conncted to 875 via HDMI.
Have set everything up as per manuals and left most things on default for time being (RSW12 low pass filter off etc), however even with RSW12 volume set quite high I am getting very little from it. It does react to explosions in films etc however at that volume I'd be expecting the house to shake rather then the low rumble I am currently getting. Have checked LFE settings on 875 and they are all set to 0db as default so doesn't appear to be a problem there? Not sure if I'm doing anything else wrong or it the Bi-amping is causing a problem?
Having looked at speaker config on the 875 it would appear that the Fronts/Center/Rears are set to full band whilst the RSW is set to 80hz. Could this be causing the Sub to cut out to early to leave the remaining speakers to cover the lower frequencies?
If so, will playing with these setting get me a better setup?
Thanks guys.
