A few very quick questions to help me clarify what I think I know about lossless music….
Currently, most of my music is stored on my computer for use on my iPod at a high MP3 bit rate.
As I will soon be purchasing a good hi-fi system I am going to start importing my CDs again using lossless compression. These digital files will be my main source of music and I want the information in these files to be EXACTLY the same as is on the CD. Ie. There should be no difference between playing the CD or the imported digital file through the same DAC.
Is this achieved with lossless compression?
Does the computer/sound card affect the imported file?
Does the importing software affect the resulting imported lossless file?
Is there a difference in apple lossless or wav? Are there any other options I should consider?
Does converting between lossless files affect the data ie. ( if I convert a wav file to flac, convert this flac to apple lossless and then convert this apple lossless to wav, will the two wav files be exactly the same?)
Thanks for the advice,
Conor
Conor
