Thanks for your response. I have a few dealers I can visit so hopefully be able to compare with my Spendors. Good to know I might struggle to improve on what I have.Welcome to the forum.
Presumably you want to buy new?
Speakers can be quite personal and very dependant on the room they are going into.
Can you get to a dealers to audition wherever you are?
You might struggle to better your Spendors , that originally cost approximately £1200, for your budget.
Whilst the presentation of some modern speakers may be different only you can tell if they are better....
audition whatever you can within your budget. Speakers like the Dali Oberon 7 etc come to mind but not sure what is actually available in your area.Thanks for your response. I have a few dealers I can visit so hopefully be able to compare with my Spendors. Good to know I might struggle to improve on what I have.
Agree with the others, you'll really struggle to improve on those Spendors. Not only are they very good but tonally they should be the ideal match.Thanks for your response. I have a few dealers I can visit so hopefully be able to compare with my Spendors. Good to know I might struggle to improve on what I have.
Well that's a novel approach... 🙂I don’t think your amp will be getting the most from the S5es. I remember they felt pretty inefficient compared to similarly priced speakers, so maybe look at some muscular amps to try out. Again though, you may struggle to greatly better the Elex with the same amount of money unless you look at something used or ex-demo.
possibly, although the S5e were slightly more efficient than those A1s.I had a Rega Elex-R with Spendor A1s, and to be honest the Rega was fairly hopeless at driving them. It's a great amp, but not necessarily the best fit with more challenging loads.
I feel all too often (I’m saying the same in this instance) that people automatically want to change the speakers when they’re not happy with their system, maybe because they feel it’s going to make the biggest difference. But more often than not, their existing amplifier isn’t doing a great job with their current speakers, so moving up to even better speakers (the better the speaker, the more demanding the load, in general) is just going to make things worse, despite the speaker doing things in a different way to the older ones so will bring about some change.Well that's a novel approach... 🙂
I feel sure you may be right as I haven't heard a Rega amp in years.
If I recall correctly a poster years ago (can't remember the username) had these speakers and he powered them with a entry-level Quad pairing, which I don't think was anymore powerful than the Elex-RI don’t think your amp will be getting the most from the S5es. I remember they felt pretty inefficient compared to similarly priced speakers, so maybe look at some muscular amps to try out. Again though, you may struggle to greatly better the Elex with the same amount of money unless you look at something used or ex-demo.
Don't know what Current Dumping is. Never heard of it.It may be that the pairing in question used QUAD's Current Dumping design, which would explain things.
Thanks Matthew. Never heard of that before, mind you I've never seen any of the Quad amps in the flesh.The QUAD 405 Current Dumping Amplifier | Hifi Pig
Janine Elliot continues her RetroBites series of articles, where she looks at classic audio and Hifi, with the classic QUAD 405 current dumping amplifiers.www.hifipig.com
As matthewpianist has explained. Quad’s current dumping system increased the amplifiers capabilities when driving more demanding speakers.If I recall correctly a poster years ago (can't remember the username) had these speakers and he powered them with a entry-level Quad pairing, which I don't think was anymore powerful than the Elex-R
Actually I think the person I'm thinking about had Spendor SA1, which could be tricky to drive, as I demoed them when I first purchased the LeemaAs matthewpianist has explained. Quad’s current dumping system increased the amplifiers capabilities when driving more demanding speakers.
There are 50wpc amps for £300, and there are 50wpc amps at £5,000, even more, which shows that an amplifier shouldn’t necessarily be dismissed on its power rating, more on its capabilities. The £300 amp would melt driving some of the same speakers the £5,000 one would be capable of driving.
