Long HDMI Cables 1080i and 1080p differences.
I am planning a ‘clean’ (no visible cables) ‘on wall’ installation of a large screen 1080p TV (Panasonic or Sony). The cable run will be almost 10m, and will include 2(or3) hdmi, 3 sets speaker cable, a set of component cables and a Co-Ax Aerial cable. (Power will be separate). I plan to place these all within a conduit to arrive from outside through a wall to the TV. Some concerns I have are as follows .................. 1)Will any of the signals interfere with each other? 2) Could I use an HDMI cable splitter/router box at the component end and route just one long HDMI cable to the TV? Already convinced of the benefit of quality HDMI cable, particularly for a long distance, the cost of two or three 9m/10m cables will be considerable. 3) Why are the HDMI connections on the Sony STR-DA1200ES, which is fairly new, limited to 1080i? I was going to route them all through this AV amp, but routing a 1080p output through it would be pointless, hence the individual cables. 4) I also think that having read some very detailed stuff about 1080i vs 1080p that most viewers will not be able to tell the difference, any comments? Thanks
[quote user="filmmad"]1)Will any of the signals interfere with each other?[/quote]
You should be okay, it's power you should keep separate.
[quote user="filmmad"]2) Could I use an HDMI cable splitter/router box at the component end and route
just one long HDMI cable to the TV? Already convinced of the benefit of quality HDMI cable, particularly for a long distance, the cost of two or three 9m/10m cables will be considerable. [/quote]
I guess so.
[quote user="filmmad"]3) Why are the HDMI connections on the Sony STR-DA1200ES, which is fairly new, limited to 1080i? I was going to route them all through this AV amp, but routing a 1080p output through it would be pointless, hence the individual cables[/quote]
Unfortunately short sightedness/ couldn't be bothered on Sony's part.
[quote user="filmmad"]4) I also think that having read some very detailed stuff about 1080i vs 1080p
that most viewers will not be able to tell the difference, any comments?[/quote]
What size screen are you after? 1080p is worth it on a 50", 46" possibly, below that pointless. Some sources look better at 1080p, some at 1080i or720p. suck it and see.
Personally I would ditch the amp and get one that can switch 1080p, and upscale too. So much easier for integration. How much are you going to pay for a couple of runs of good quality 10m HDMI cable?
EDIT:::::Just looked and your amp should switch 1080p after all.
http://www.sony.co.uk/view/ShowProduct.action?product=STR-DA1200ES&site=odw_en_GB&pageType=Overview&category=HCS+Home+Cinema+Receiver
R
