D.J.KRIME:
maxflinn:good point , but i still dont recall any differences of late , is it therefore fair to say that whilst its impossible to assume parity of performance , it is far more likely than not that there will be no difference ?
Max sometimes I find your posts rather how shall I say without sounding rude which I don't intend to pointless or simply based on guess work, and dare I say it without upsetting you, your way off in presuming that because a 50" model proforms well that a Larger model in the same range will follow suit as there are many differing factors to take into account. The spec sheet may well read the smae for both 50" and 60" models but not all components may be identical eg Power boards and transformers etc which can effect proformance, also as Andrew has mentioned the pannels may well have been made in diferant factorys or even differant companys.
dj , i wasnt presuming as such , i was inviting conversation/views/comments etc , on the likelyhood of proformance differences or not , as i said , i dont recall reading any reviews that mentioned differences in performance between same model plasmas (example . kuro 5090 .. 6090 ) , so , i was making the point that on the balance of probability , given no recent documentation that i recall , of differences between plasmas of various sizes , is it not fair to say that such differences , even allowing for manufacturing variables , are more unlikely , than likely , to be found ....
