Klipsch Rf-62, Dynavoice Challenger M-85, Q aqoustic 2050i.
jef
What's the best choice between these speakers : Klipsch Rf-62, Dynavoice Challenger M-85, Q aqoustic 2050i. I'm listening progressive house minimal mp3.. Using LCD or loptop for player and Denon AVRX2000 receiver. please help to choose the right one 🙂
How big is your room?
Is this for domestic or DJ use?
What kind of sound do you like?
Have you or do you plan to listen to any of them?
Why those three?
And then we might be able to help.
my room is about 20 square meters. it's for domestic use. i like crisp, clear and tight sound. Why those 3? it's in same price range and i never had listen these. just i need couple speakers for music..anyway it's moore than i had before
I know nothing about the Dynavoice, the Klipsch on the other hand is big, loud and probably a bit unruly. I say probably because although I am familier with some modern Klipsch designs I have not tried that specific model.
The 2050i is more 'britsh', a little more reserved and easier on the ear, particularly when listening for some time.
If you have the space and want 'party' levels go for the Klipsch, for more 'refined' hi-fi listening, get the Q Acoustics.
The horn tweeter on the Klipsch is a tad on the rough side according to some reviews. The Qs are more refined, but the treble can be brighter according to Hi FI World's review. No idea what your other speakers are like, but of the three, I'd take the Qs. Not without refinement and terrific value for money.
