Kitchen TV Wall Bracket Question
piper1st
I bought a white 22" TV (SONY BRAVIA KDL22EX310) for our kitchen the other day, and now looking for a suitable bracket to mount it to the wall.
Link to TV - http://www.richersounds.com/product/lcd-led-tvs/sony/bravia-kdl22ex310/sony-kdl22ex310
The TV will be on the wall in the middle between the kitchen area and the dining area, and so i need the TV to be able to turn a full 90 degrees left and a full 90 degree right.
The TV Spec is as follows:
# Dimensions: W:529 x H:347 x D:42
# Weight: 4.1 KG
# Type of Fixing: VESA - 100 x 100
Can anyone recommend a good wall bracket thats able to be swung around easily in both horizontal and vertical movement?
I suppose the arm needs to be at least 26.5cm long as that is half the length of the TV?
Oh, and why do you never seem to get tv brackets in white? I don't mind spray it white myself though. :rofl:
Great shout BigBoss ... thank you ... perfect colour, perfect reach, flexible mounting options ... but £90!! :O :cry:
It can hold up 27Kg's which is impressive, but my wee TV is only 4.1Kg's ... so perhaps over kill! Any cheaper options?
