Newb here, signed up to reach out as ask for some advice.
Here's my setup:
Kef LS50W II + S2 stands + Kef Sub (Kube 10b).
Pro-ject X2 turntable for analog and Tidal Connect for digital.
Generally great set up, simple, lovely sound. Now just trying to optimize a few things.
High pass / low-pass questions
1. I used to have both the High-pass and the sub out low-pass frequencies at 80Hz (in the Kef app). Now experimenting with 95Hz for both. Is it recommended/necessary to have both frequencies be the same? They are 2 different sliders in the Kef app, so I can choose say 80Hz for the High-pass and 100 Hz for the low pass.
2. Any recommendations on setting up the high and low pass frequencies? I feel that I hear more detail in the bass when the low-pass is at 110Hz. Anything wrong with that?
Side note on the Sub's physical dials. The volume is set to max and the crossover to LFE. Anything I should change here or just make changes in the app?
Adding an extra sub
The Kef LS50W II (unlike the original version) accepts 2 subs. Would I be improving the bass response by adding another Kube 10b? I know that adding a 2nd sub improves the general distribution of the bass in the room, but will the quality /detail/tonality also improve?
Room correction
Outside of the EQ settings in the Kef app, are there easy ways to do some basic room correction? I have no room treatment for the moment, but the room they're in has 2 big rugs and lots of books. Not real acoustic treatment, so looking to see if I can improve on that somewhat. I don't use Roon and feel somewhat intimidated by that process, is there an easier way?
Other recommendations
Outside of the questions above, are other ways I can extract more quality from this system? open to ideas and thoughts.
Thanks for any thoughts can help me continue to improve the set up!
Here's my setup:
Adding an extra sub
Room correction
