Just few questions so I understand about speakers
muljao
334
91
10,970
Why generally are floorstander speakes higher in sensitivity?
Does a higher sensitivity nean they are easier to drive (always)? What i mean is should say a NAD D 3020 in theory (30w perchannel into 8 ohms) drive say q acoustics 3050 relatively easy becuase they are 92db (these are only examples, I am not buying, just trying to understand)
Is better bass the main advantage of floorstanders (obviously within specified budgets compared with standmounters)?
Generally, they have a significantly larger cabinet volume. For a given bass output (volume) and extension (how deep), the bigger cabinet enables the efficiency (sensitivity) to be higher. Conversely a small stand mount speaker needs a bigger magnet assembly to match, which puts up the cost. So in a budget speaker, a bigger box usually gives you 'louder' and 'deeper'.
"Easily driven" is more a function of minimum impedance - it's not a fixed figure, but varies with frequency. Nothing to do with sensitivity. The lower impedance actually draws a larger current from the amp; which a weaker amp won't like.
Bigger floor standers can actually have awkwardly low impedances, but under a grand you usually get something fairly easy to drive.
Im general Floor standers produce more bass due to cabinet Volume. The sensetivity in db is generally easy to drive if higher, you get more volume given from a given output. The load in ohms is a gudie how easy it is for a speaker to drive.
The gain in bass from a floorstander is often comprimised with a overhang in the bass Stand mounts generaly have a tighter bass better timing and pace, but cant reach down for the deep bass.
as a rule a standmount will produce better dynamice at a given price. what i mean is a £500 standmount will be better than a £500 floorstander, you have to spend double £1000 to match the standmount
