j river media 20
Andrewjvt
99
Can anybody tell me if jriver 20 does an auto error correction when ripping cds
Use rip the cds in flac format
I believe that it does when you choose secure mode,
http://wiki.jriver.com/index.php/CD_Settings
regards
J Rover MC has had the error check capability from the start (it certainly did in #13 which is where I started).
You need to set it up in the option menu where you also select the default file type, it's pretty straightforward. each time you rip a CD, it produces an error report, so you'll know if it was unable to read some of the data. FWIW, I've never had a problem on two different PCs but that is down to the hardware as much as anything.
Steve.
Ill check next time i rip a new cd. Not gonna re rip all the other though . Took my ages.
Ps getting my hegel in 2 weeks
