itunes and 2 ipods.
avnut
56
can someone assist me? trying to sync 2 ipods on itunes but all i seem to manage is to delete one or the other. im sure it can be done but its beyond me.greatfull for any and all advice,thanks
Jason36
427
You can actually set up a seperate library for second and additional ipods, this works well if you have different tastes in music or want a different type of genre on each ipod.......saves having to keep ticking and reselecting you songs each time you want to sync.
That was the easy bit, now unfotunately I cant remember how you do it......should be a link on the apple help website...If I remember you hold down one o two key when you start up itunes and you can then create a new library.
Hope that helps
