I have a much loved Yamaha A1000 which has been the centre of my Prologic system for more years than I care to remember. When my old CRT TV died I upgraded to a plasma and bought my son a PS3. I still have my SVHS Panasonic and a new EX78 DVD/HD recorder. I can no longer use the yammy as a video switching unit (it has never heard about HDMI nor even optical). Worst of all I have to listen to Blu-ray movies through the TV speakers.
I've toyed with the idea of buying a cheap processor to take the sources and pass the audio (at least) to the amp - but they are not that easy to find unless you have high end kit and then they are not cheap.
Should I simply bite the bullet and get a new yammy (lots of good write-up's at the mo') and if so any good ideas what best to do with the old one (which can't be worth much to anyone else)?
Some time ago I had the amp upgraded to 5.1 discrete by a company called Videotec but sadly they no longer do this kind of work. Why can't old amps be upgraded or future-proofed (apart from it not being in the manufacturers' interests)?
All advice gratefully received.
