I have been a reader of the magazine for many, many years, and whilst this sounds REALLY crawly, I think your publication is the best available, and I am thrilled with the response from the magazine on a couple of issues I have raised recently. I would not purchase it regularly join your forums or return questionnaires otherwise, and I think that of all the features in the mag, probably the most useful, helpful and influential is your buyers guide. It compares products, gives basic technical spec, recommendations and observations of products you have actually tested and anyone would be foolhardy to not utilise this facility and even get a back issue to fully appreciate this on a prospective purchase.. I do have a proposition however that I feel may make this section even BETTER. I would like to see an additional column in the section, as unobtrusive as the £ column, that gave a product an OVERALL percentage rating, irrelevant of price, based on your current reference model which would hold the 100% title. This would allow the selection of a product based on performance, not performance dependant on cost, and would also allow a result in excess of 100% for new or exotic ultra high level products. At the moment, I find it difficult to select a product if it has a 5 star rating in an "up to £100" catagory, against a 4 star product in a "£100 - 200) catagory, because the 4 star product may be better, and only slightly more expensive, but have less value for money. An "ULTIMATE" rating would make this choice far easier. An example if I may, and one very relevant to myself recently is a comparison between the 5 star B&W 805 and XT4's at the same price or the £1000 more expensive B&W 804's. Are the 804's worth the extra £1000? There is nothing to gauge this and nothing to say catagorically they are in fact better anyway! I hope you see my point. Keep up the great work and good luck with the mag. Gerry, (Oldskool)
