In ear headphones for gym???
Chr78
128
The ones that do not fall out of the ear. And the ones with big sound and detail/clarity and bass. Max 90 pounds. Recommend!
I find that in regular gym use, 'phones do not last more than a year or two.
I use inexpensive Soundmagic models, currently PL21. Not £90 good but as good as anything under £50-60. The PL30 feel a bit more heavily built but sounded just a touch too bassy for me, though I do like a light, fast bass. Might suit you.
If they get lost or broken then it is no big deal at those prices.
I use etymotic research 6i's with the expanding foam type plug. I find it stays in your ears even when you have swear pouring off you. The rubber mushroom type tips tended to fall out.
I always use Shure IEM, they sound good but are also the style that the wire comes over the top of ear which I find a smugger fit, along with the assortment of ear pieces they come with you can choose a pair that fir really smug.
