I have some TDL rtl2's I'm considering getting a pair of Toshiba ss.33 mk2s and pairing them in stereo, is it worth it?
Please explain a bit more on how you intend to pair these in stereo.I have some TDL rtl2's I'm considering getting a pair of Toshiba ss.33 mk2s and pairing them in stereo, is it worth it?
If you mean you'd be running both pairs simultaneously (all 4 speakers), that's not advisable.The tdls are ancient, you plug them in to the same out puts on an amp
It depends whether its in series or parallel, according to Gemini AI. If its in series it can actually increases the total impedance.If you mean you'd be running both pairs simultaneously (all 4 speakers), that's not advisable.
The way he describes is parallel so he is having the impedance so will need double the current. Wiring in series won't really help either, then as you say he will halve the impedance, so then he will need double the voltage just to maintain volume.It depends whether its in series or parallel, according to Gemini AI. If its in series it can actually increases the total impedance.
Who knew?
Yes, but that way won't damage the amplifier. If I've got this right.The way he describes is parallel so he is having the impedance so will need double the current. Wiring in series won't really help either, then as you say he will halve the impedance, so then he will need double the voltage just to maintain volume.
Series won't damage the amp, he will just have the volume cranked up high.Yes, but that way won't damage the amplifier. If I've got this right.
Yes series connection will increase the overall impedance.It depends whether its in series or parallel, according to Gemini AI. If its in series it can actually increases the total impedance.
Who knew?
you don't run two pairs of speakers from the same binding posts, as pointed out above.The tdls are ancient, you plug them in to the same out puts on an amp
