If you had £2000 to spend on speakers. What would they be?????
I can hand-on-heart say that if you took my B&W MT30s away and dropped £2k in my lap, I'd go straight out and buy another set of MT30s.
Basically, with my current room, my current Wife and my current requirements, I can't think of anything better for the money.
Of course if I had a massive room or a blind Wife or somesuch, I'd undoubtedly go for floorstanders in all 6 surround locations with a matching centre, but that'd probably bust the budget too.
I would try and get a second hand pair of £4000 speakers for £2000. I,ve never heard a pair of £2000 speakers that sounded like they were worth the price. Don,t think there is much difference when you go above £1200 and compare them with £2000 worth of box.
lewy20004:
Just wanted to get an idea. if you had £2000 to spend on speakers what would they be?? and why?
Hi lewy2004
I would consider the following
For 2ch - ATC's SCM19's or the SCM40 as overall i believe the 40's to probably be the finest VFM speakers currently available on the market irrespective of price.
For AV - Monitor Audio's Silver RX AV6 package, Apex sub/sats or ATC's Concept 1.
All the best
Rick @ Musicraft
Lewy20004,
Assuming you are referring to home cinema speakers, it would have to be either a Monitor Audio Silver RX6 AV12 or an M&K M-7 system for me.
Ronald
Would love some RX6 speakers with RX1 in the rear for home cinema..................
Oh wait its coming this week........
Cant wait.
AV or hi-fi? New or used? Seems to be a bit of a mix so far....
From what you have said, I'm assuming 2 channel hi-fi. My choice would depend on amplification, but it would be between the ATC SCM19 and the ProAc Response D18.
Used? KEF Reference 4.2's....
And all those strictly within budget....
