Humming through XLRs
Mark Dunlop
41
31
1,570
I recently bought an Audiolab combo - the 8300CDQ & 8300 XP and decided to try the XLR ouputs for a wee change. I then bought replacement speakers - B&W DM602 S3s out, ATC SCM 11s in.
There's a hum from the speakers when I select the XLR output on the 8300XP which is not present when I select the RCA outputs. I don't think the B&W speakers hummed, but I've sold them and now can't be sure. XLR leads are new from Designacable. RCA leads are home-mades.
Wasn't expecting XLRs to hum, and certainly not when RCAs don't... anyone got any clues?
m.d.
Mark Dunlop
41
31
1,570
Could be a faulty unit, also the XLR are at both ends and not going from XLR to RCA.
To be honest, for such a short length there is no advantage to XLR over RCA.
Bill
Cheers, Bill. I only decided to use XLRs for the s & giggles, really. I would say the sound is a little louder through them than the RCAs and the hum isn't apparent when listening.
I had a hum from a Rotel cd player once that I fixed by using a different power cable, but this is a different kettle of fish.
m.d.
Gray
.....so they're probably ok.
But, if you've got a multimeter, you may as well check to confirm all is well.
You'll see the XLR pins are numbered 1,2,3 (printed on the plastic close to holes and pins).
Use continuity test to confirm all go to the corresponding numbers, plugs to sockets.
Pin 1 is the screen.
Will (should) have been tested prior to sale, but no harm in checking.
