Mark674 said:Need a bit of help please folks
I have a Cambridge azur351a amp output 45w per channel which is not very old
How can I increase output,would a power amp help?
jjbomber said:Mark674 said:Need a bit of help please folks
Yes in a nutshell. The rec out of the Azur would go to the line in of the power amp. But.....
45wpc should be plenty loud enough for domestic use. The problem may well be elsewhere. Check the speakers connections are correct. Is it too quiet with all inputs or just one? What speakers are you using?
Got a pair of monitor bronze 5 in the lounge and a pair of B&W in the kitchenAl ears said:jjbomber said:Mark674 said:Need a bit of help please folks
Not too sure where he mentioned quiet. However you are correct in that the amp should be sufficient for most but the more inefficient speakers in a normal domestic environment.
Perhaps the OP could add a bit more info as to why he feels that he needs more 'power'.
Mark674 said:Got a pair of monitor bronze 5 in the lounge and a pair of B&W in the kitchenAl ears said:jjbomber said:Mark674 said:Need a bit of help please folks
Blackdawn said:Maybe you have insensitive speakers?
DocG said:Mark674 said:Got a pair of monitor bronze 5 in the lounge and a pair of B&W in the kitchenAl ears said:jjbomber said:Mark674 said:Need a bit of help please folks
Hi Mark,
Do I understand correctly that you drive two pairs of speakers off the same amp (together)? If so, that might give your amp a hard time!
...and if they still block your path, when asked to move, they have a high level of impedence.steve_1979 said:The best way to test how sensitive they are is to call them rude names and verbally abuse them. If they don't flinch then you know they're insensitive.
Sorry.
CnoEvil said:...and if they still block your path, when asked to move, they have a high level of impedence.steve_1979 said:The best way to test how sensitive they are is to call them rude names and verbally abuse them. If they don't flinch then you know they're insensitive.
Sorry.?
Sorry.
Ohms my Lord, watt a thought.steve_1979 said:CnoEvil said:...and if they still block your path, when asked to move, they have a high level of impedence.steve_1979 said:The best way to test how sensitive they are is to call them rude names and verbally abuse them. If they don't flinch then you know they're insensitive.
Sorry.?
Give them a gentle push with one finger. If they fall over they have very little resistance.
