How to get the best sound out of Blu Ray films on PS3
If i connect a ps3 through my Denon 4308 amp with HDMI can i get full hd surround sound from blu ray movies or what is the best way to get the most out of it
professorhat
992
22
18,895
This review suggests the Denon can output an HD soundtrack. Whether it's the best you can get is something you'll have to decide I'm afraid, but if you already own it, you're pretty well set I reckon!
Liam19
35
mark8par:If i connect a ps3 through my Denon 4308 amp with HDMI can i get full hd surround sound from blu ray movies or what is the best way to get the most out of it
Yes, you can certainly get HD sound from this combination - just make sure to set the PS3 to output Linear PCM audio via HDMI, then it'll decode Dolby TrueHD and DTS-HD Master Audio onboard and send to your Denon.
Keep in mind, however, that doing this doesn't utilise the decoder inside the Denon, and so it won't display DTHD or DTS-HD MA on its front panel.
If I'm honest though, with an amp worth £2,000, I'd consider investing in a more upmarket Blu-ray player that can bitstream HD audio codecs to the Denon via HDMI, so that its (most probably) superior decoding capabilities are put to good use. It's bound to sound better again!
Hope this makes sense to you!
