- Aug 10, 2019
- 2,556
- 5
- 0
As you know I'm fairly new to home cinema, and I decided to start my own home cinema project.
In a few months I will have all these components:
TV - Plasma Samsung D8000 (almost sure of this buy, however I will check out the panny VT30 as well)
Speakers - MA RX6 AV12
Receiver - Pioneer SC-LX83
My HTPC. (specs can be found here)
Synology DS1511+ NAS with 5x 7k3000 Hitachi Deskstar
PS3 (already own it)
Sky HD
I already have the following Network:
Speedtouch ADSL2+ 546(i) v6 Modem
Linksys E4200 Router
Hp ProCurve V1810-8G Switch
The modem is connected to the Router. The Router is connected to the switch. And whatever I need on my network will be connected to the switch as well. Everything is setup with CAT5e or CAT6 cables (mixture of the 2).
However I am unsure about how all the components will go together.
From the little knowledge I have, the PS3, Sky HD, Speakers and HTPC will be connected via HDMI to the LX83 AVR. The LX83 AVR will be connected to the TV via HDMI as well.
However when it comes to the NAS I am unsure of where or what will be connected to the network. I know that The NAS will be connected to the switch. But the AVR also has a LAN port. Should it be connected to the switch as well or not? Also, for the NAS I was planning on streaming to my HTPC and view the Movies from there. How can I achieve this exactly? I am thinking of using XBMC on the HTPC (will be connected to the switch as well).
I am pretty confused about all these connections. Also I am pretty unsure whether I should use 2 Gigabit connections from the NAS to the Switch? (I think the HDD on my main PC will be bottleneck - I have a Samsung F3 1TB hard drive which will be updated with a 120GB SSD if needed). I understand with 2 LAN wires to the Switch I will have faster transfer speeds and better for streaming?
If someone can shed some light how to properly set up all this equipment, that would be great!
Sky HD
