How do you attach your speakers to their stands?
My Soundstyle Z1 stands have spikes on the top for the speakers to rest on but i'm going to get some new speakers and wondered if there was a less damaging way to do it. I used to just use bluetack when i mounted them on shelves.
Nothing more technical than blue tack for me! As yet I havent seen any audiophile blue tack which improves the sound, but if I do I'll probably give it a try...
Mixing blue and white, 30% blue to 70% white gets the best overall results.
(The above may have been made up and totally wrong.)
JohnDuncan:I use white-tak, which is actually better than blu-tak in terms of imaging.
Excellent news John.
Tesco only had white Blu-Tack so I had to use it for my new speakers.
I've got Red-Sparkly-Tack for Christmas, adds a layer of sleigh bells to every piece of music. Sounds great on Rammstein!
White-tak is good for a broader range of frequencies. Blu-tack is good for the highs, Red-tack for the lows. Pink-tak would also be good, but only if C-Weighted.
And yes, blu-tack may discolour the veneer a little but, that's why you stick it to the bottom of the speakers and not the sides..
al7478:What about it pulling the veneer away with it?
Thats what those flippy plastic slice/spatula thingies in the kitchen utensil drawer are for. (Gently seperates speaker from top-plate without marking veneer by 'slicing' horizontally through the Blu-Tack first.) Just select one that is thin enough to go in the gap.
Blue tack works really well but it is directional, be sure to stick it to the speaker first then to the stand.
