You could try one of these:I’m planning on buying an amp and streamer, but don’t have space for a cd player
I would use a laptop or desktop PC with a DVD or Blu-Ray drive. The DAC Magic 200M has a USB and optical input. You would simply play the CD's from your computer.I was looking at a NAD / Cambridge amp and streaming set up. Could I burn them onto something that either device can read?
The EAC that you've mentioned will read and convert your burned CDs into FLAC files......I just don't know what I need to transfer or read the burned CDs.
Yes, if the NAD has the ability to play FLAC files from a USB socket, that's exactly what you can do 👍So I copy the files to a USB, stick it in the back of the NAD amp then access them via the NAD app?
The Cambridge CXA61 has a USB audio in socket, which I don't recognise (compared to a standard USE for stick).
Cambridge Audio CXA61 (Lunar Grey)
Shop for Cambridge Audio CXA61 Lunar Grey Stereo Amplifier with Richer Sounds for expert advice and lowest prices guaranteedwww.richersounds.com
Can I do the same thing into that socket? What else would I need?
Unfortunately the IOTAVX doesn't rip CDs, it just plays them. A standard laptop with external CD drive will rip them. Software like Exact Audio Copy is ideal for such a scenario.That IOTAVX might be just the thing! Does that IOTAVX burn them onto it's hard drive, too? Then match it with their amp https://iotavx.com/IOTAVX-PA3_1 ?
Start @ £650 new and massively overkill for something as trivial as music streaming, and nothing like as plug 'n' play as a streamerI still find the simplest way is to run a headless Mac mini in your hifi rack and connect that directly to a dac forgoing the streamer altogether.
They are more engery efficient and cheaper than any streamer.
Run a program called audiovania and you’ll be able run from your phone/tablet and it will run tidal and your music collection seamlessly as one like roon.
Do Apple silicon Macs even boot headlessly or do they require the HDMI dummy Intel Macs used to incidentally?
A bold claim!
According to Apple an M1 MM uses 6.8W at Idle and 39w with CPU maxed, its 7 - 50w for an M2 and 6.8 - 85w for a Dual core i5 intel MM.
Whereas a Wiim Mini is supplied with a 5V, 1A PSU and a Wiim Pro a 5V, 2A PSU. So that's 5W and 10W respectively MAX
As for cheaper....
An extra £100 and only two years of OS compatibility upgrades guaranteed or an ongoing subscription
