hooking up NAD D 3020 amp to Marantz CD6005
monkeymatti85
hi there i recently brought a new NAD D 3020 amp and Marantz CD6005 cd players
everything is working well when connected with the 2 phono cables , i have been trying to connect them with a TOSLINK optical cable
but i am getting no sound from the speakers , i was wondering if these 2 items are able to be connected by optical cable or if if i am doing something wrong
thanks
Is it not to do with the input selection i,e what did you select for the 2 phono cables input. Just a thought are you choosing the optical input on your selector on the amp
thanks for the reply
yeah i have tried selecting optical 1 which the cable is connected to on amp, but no luck
works with the other audio cables when i change to aux 1 setting , trying to get connected with optical so can also connect record player upto it
If you have selected the optical input on the input selector of the amp and the optical lead is definitley connected correctly and not damaged (no sharp bends, or kinks) then you have a fault.
I see there are Two digital inputs one has a plastic plug in it and the other is above the coaxial input try both optical 1 and 2 options on the amp to see if one of them work
hi - why would you wanna use the digital out of the marantz in the first place? You do realise that basically, if you use a digital connection between the two, you'll just bet using the NAD's dac and the Marantz will only be spinning discs - which might as well be a cheap DVD player with a digital out, or a laptop, or whatever. I mean sure, go ahead, if it's for experimentation or you don't like how the Marantz sounds, then it's ok. Otherwise, just use RCA cables from the Marantz, or sell it and get a cheap DVD player with digital outs 😛
Good point. My marantz receiver / amp ( not home cinema ) hasnt got digital inputs I have got a Marantz cd player which I dont really use anymore because I stream most of my music from the Mac to a Crystal Blu-dac reciever which as the name suggests it has a built in Dac and I find that it sounds good the only problem is with the Mac is it hasnt got a built in disc player so if I did want to play a disc then I would use the cd player which is connected with phono interconnects.
It should work. I have never used the cd player so check to see if there is provision to turn the digital outputs on or off.
If you have a spare cable try the digital co-ax connection or even optical 2 if you have the adaptor.
Try both these and report back.
You should have digital out on by default, but if you have selected audio ex in the sound mode menu, it turns the digital outputs off.
