home cinema , what to buy
hi
im confused , what to buy
my room is 4 meters by 3 meters
is it worth me buying a full 5.1 set up , or would it be better if i just brought say B&W 684
5.1 surely is too much , the room seems small , cos some ppl here talk about 8meter long rooms etc .....
thanks
I guess it depends what else is in the room except for the TV and surround system?
For example if you just use it for a kind of snug theatre room, with just a sofa in it, it could work out OK...
The 684's maybe a bit excessive though, maybe you could think about the 685's?ÿ
thanks for feedback
room is mainly a tv room , big corner sofa and then tv there aswell
7.1 woah , u must have sound everywhere
i dunno what to buy , cos say i start off with 2 fronts , midrange and then expand later , or go say Q Acoustics 1010i
anything is better than nothing i suppose
plus i guess i need to go to a store , for a demo
sevenoakes loughton
Quamar:
well then there is the 2 speakers for the HiFi as well 😉 Yes 2 totally separate set ups.
