Home Cinema Speakers - Monitor Audio vs B&W
I cannot find a retailer who demonstrates both and am trying to choose between the B&W MT-30 and Monitor Audio R90 HD10. When I mentioned the B&W system to the Monitor Audio retailer, they suggested upgrading the front speakers to R225 HD's which would get to £1,500 and sound better! I recall the chosen amp as being a (What Hi-Fi) best buy Denon or Yamaha and basically have not committed yet as I could not decide what to do. Help?
Best bet is to visit two dealers... if you're worried you won't remember the difference then try to schedule the auditions for the same day. If you really can't decide once you've listened to them both, it means you'll probably be happy with either system's sound!
Based in Harrow, Middx David. I will look you up on the link and get in touch.
